Firmware update 8.20 NaviDrive RT5
ariec4
Totaal aantal Berichten: 65
Geregistreerd: 31-03-2009
Gepost: 13 juli 2011 08:14 PM
http://www.eurovan2.com/forum/wip-com-rt4-rt3/10604-la-8-20-pour-rt4-rt5-est-disponible-enfin.html
Corrections on RT4
• freezing screen
• Blocking on the home page
• Slow at boot
• Shutdown and restart the system random
• Display the phone number instead of the contact during a call-in or call log
• No random POI detection radars
• At startup, black screen with the message “HARD DISK EXAMINATION”
• Loss of the map display after a software upgrade or mapping
• Poor contact displayed during a phone call `
• Shutdown and restart when crossing an intersection in Madrid
Corrections on RT5
• freezing screen
• Slow at boot
• Poor sound quality in Bluetooth mode
• Incompatibility between the partial or complete, and some Bluetooth phones
• No detection of a USB stick after a power contact
• Blocking in USB source
• Block man-machine interface in USB source
• Display the phone number instead of the contact during a conversation or in the call log
Improvements made by the updated version 8.20
• New trademark logo on the home page
• A loop shaped into refined radiotelephone which can be repaired with an updated version 8.20
• New POI icons for garages and concessions Peugeot and Citroën
• Possibility to update a mapping version earlier than this on the radio
• Backing up user data (history of recent guides, history of the last phone calls, radio frequency memory, ...) after updating to version 8.20
• Improved detection of POI radars
Grand C4 Picasso 1.6 THP EBV6 Ligne Business
mhondebrink
Totaal aantal Berichten: 15
Geregistreerd: 04-01-2006
Gepost: 01 augustus 2011 01:00 PM
Heeft iemand deze update al geinstalleerd?
Zijn er verbeteringen te merken?
ariec4
Gepost: 01 augustus 2011 06:45 PM
Ik heb de update geinstaleerd in de hoop dat de bluetooth na twee jaar misschien wel eens een keer zou gaan werken. De bluetooth werkt en dat is een hele verbetering. Echter, het klinkt nog steeds heel blikkerig met veel achtergrond geruis. Ik blijf daarom voor het bellen de Parrot Carkit gebruiken i.p.v. de RT5.
Verder is het opstartscherm, met het nieuwe logo, het enige verschil dat ik heb kunnen waarnemen.
Max BrainBox
Totaal aantal Berichten: 75
Geregistreerd: 29-09-2009
Gepost: 03 augustus 2011 03:19 PM
Ik heb de download gedaan en de files op een USB stick gezet. Mijn RT5 herstart, het scherm blijft een minuut of drie zwart en na het opnieuw opstarten sta ik nog steeds op 8.11.
Heeft er iemand een tip?
2 x BX, 2 x Xantia, 2 x C4 Picasso—> 6 x gelukkig
davida
Totaal aantal Berichten: 46
Geregistreerd: 18-03-2008
Gepost: 06 augustus 2011 11:39 PM
Ik had hetzelfde probleem. Heb vervolgens de .ISO file die ik had gedownload op een CD gebrand en die gebruikt, dat ging wel goed.
Het duurt wel even (volgens mij alles bij elkaar circa 45 minuten bij mij) en het ziet er apart uit, een soort DOS/Linux achtige meldingen over het scherm heen, maar uiteindelijk is de update wel geslaagd.
Ik merk overigens vrijwel geen verschil in functionaliteit.
Succes!
David
C4GP 2.0 16V Benzine & LPG (mei 2008) 80.000km
Max BrainBox
Gepost: 08 augustus 2011 02:07 PM
Bedankt David! Dan ga ik dat één dezer ook eens op die manier proberen.
snarf54
Totaal aantal Berichten: 226
Geregistreerd: 22-10-2008
Gepost: 10 augustus 2011 11:58 PM
.iso opgehaald en op cd gezet.
Blijft het Citroen logo voorzover van toepassing actief om te voorkomen dat ik straks een Peugeot logo heb ?
Moet ik alleen een keer een langer rit uitzoeken want rij normaal gesproken maar max 30 min…
Althans neem aan dat onderbreken meestal niet tot goede resulataten leidt…
Thx !
C4 Grand Picasso 1.6 THP EBV6 Ligne Business
Nocciola achteraf demontabele trekhaak, xenon, leer (sinds 12.2.09 op weg)
ariec4
Gepost: 11 augustus 2011 11:28 AM
Ik heb de ISO file destijds ‘uitgepakt’ met WinRar en het geheel op een USB gezet.
Met USB stick de update probleemloos geïnstalleerd. Duurde wel bijna 3 kwartier.
Het Citroën logo blijft actief. Van een Peugeot logo is geen sprake.
Max BrainBox
Gepost: 11 augustus 2011 11:55 AM
Bij mij is de upgrade niet gelukt via USB maar wel via CD. Een 40-tal minuten zonder problemen. En het gaat hier inderdaad wel degelijk over een Citroën logo (met de afgeronde chevrons) en geen leeuwtje.
davida
Gepost: 11 augustus 2011 12:52 PM
Thx !
Ik zou je inderdaad dringend adviseren de motor niet uit te zetten tijdens de udate. Dat zou kunnen leiden tot het ‘bricken’ van je boordcomputer (dwz dat hij het niet meer doet oftewel de functionaliteit van een baksteen…)
Ik heb hem zelf nog even 20 minuten op een parkeerterrein laten draaien (met de motor aan) tot hij klaar was.
David
Max BrainBox
Gepost: 12 augustus 2011 10:59 AM
Mijn eerste bevindingen zijn positief: merkelijk snellere opstarttijd en snellere, betrouwbaarder BT synchronisatie.
Over de audio kwaliteit tijdens een gesprek heb ik nog geen feedback.
Verder lijkt het of de map-display vloeiender scrollt/roteert als je aan hogere snelheden op bochtige wegen rijdt.
snarf54
Gepost: 14 augustus 2011 11:31 PM
Firmware vanaf CD geinstalleerd in denk 35 min.
Nieuwe Citroen logo.
2x gebeld en volgens de ontvangers beter.
Sync Met Galaxy S 1 goed.
(allen staan er in de syc met een Gmail acc ook een aatnal zonder telf nr, die laat de Galaxy niet zien meer de RT5 wel, zou daar nog iets voor zijn..?)
Wat wordt er bedoeld met
” Improved detection of POI radars”?
Heb ooit eens en bestand ingeladen voor NL en FR.
Zitten de radar POI nu standaard in de RT5 ?
Sparks
Totaal aantal Berichten: 622
Geregistreerd: 21-09-2007
- (Grand) C4 Picasso BlueHDi 120 S&S
Gepost: 15 augustus 2011 12:56 PM
Ik denk dat ik de update maar laat zitten. De dame wordt in maart/april 4 en dan mag ik waarschijnlijk een nieuwe uit gaan zoeken.
snarf54
Gepost: 15 augustus 2011 09:45 PM
@Sparks
Te begrijpen maar het is niet echt veel werk zeker niet als je toch wel een ritje hebt van een half uur tot 35 min.
En je gunt de volgende gebruiker van je auto toch ook plezier…?
Sparks
Gepost: 16 augustus 2011 02:56 PM
Ritjes van rond de 35 minuten heb ik dagelijks. Ik zie er alleen tegenop om de software weer op een CD te branden Wink
Totaal aantal Berichten: 2457
Geregistreerd: 18-12-2004
- C5 Aircross-Hybride
Gepost: 18 augustus 2011 03:35 PM
Bij mijn RT4 heb ik de 8.20 ingespeeld via de USB.
Dat ging makkelijk door de ISO uit te pakken mbv MagicDisc.
De belangrijkste reden voor het inspelen was dat daarmee de flitsers, die ik maandelijks bij Planète Citroën ophaal, nu rijrichting gebonden gesignaleerd worden.
Andere flitsers zie je wel op de kaart maar die resulteren niet meer in een waarschuwing.
