![Avatar](/images/avatars/uploads/avatar_5073.jpg)
Inhoudsopgave van dit topic:
1. Overzicht navigatiesystemen per model
2. Systeemherkenning
3. Controle kaartversie
4. Update kaartmateriaal
5. Verdere vragen en forumdiscussie
Overzicht navigatiesystemen per model (in alfabetische volgorde)
1996-xxxx Citroën Berlingo
1996-2009 (Berlingo I) - -
2009-2012 (Berlingo II-1) MyWay
2012-2015 (Berlingo II-2) eMyWay
2015-2018 (Berlingo II-3) SMEG+
2018-xxxx (Brlingo III) Citroën Connect Nav
2005-xxxx Citroën C1
2005-2014 - -
2014-xxxx (C1 II) Garmin nüvi
2003-2009 Citroën C2
2003-2009 NaviDrive RT3
2002-xxxx Citroën C3
2002-2005 NaviDrive RT3
2005-2009 NaviDrive RT4/5
2009-2012 (C3 II) MyWay
2012-2015 eMyWay
2015-2016 SMEG+
2016-xxxx (C3 III) Citroën Connect Nav
2017-xxxx Citroën C3 Aircross
2017-xxxx Citroën Connect Nav
2009-2017 Citroën C3 Picasso
2009-2015 MyWay
2012-2017 eMyWay
2004-xxxx Citroën C4
2004-2006 NaviDrive RT3
2006-2010 NaviDrive RT4/5
2009-2011 MyWay
2011-2015 eMyWay
2015-xxxx SMEG+
2012-2017 Citroën C4 Aircross
2012-2017 Mitsubishi/Rockford HDD
2014-xxxx Citroën C4 Cactus
2014-xxxx SMEG+
2006-xxxx Citroën C4 Picasso
2006-2007 NaviDrive RT3
2007-2012 NaviDrive RT4/5
2009-2012 MyWay
2012-2013 eMyWay
2013-2016 (C4 Picasso II-1) SMEG+
2016-xxxx (C4 Picasso II-2) Citroën Connect Nav
2001-xxxx Citroën C5
2001-2006 NaviDrive RT3
2006-2012 NaviDrive RT4/5
2007-2012 NaviDrive 3D NG4
2009-2012 (C5 II) MyWay
2011-2015 eMyWay
2013-2017 SMEG+
2017-xxxx Citroën C5 Aircross
2005-2012 Citroën C6
2005-2006 NaviDrive RT3
2002-2014 Citroën C8
2002-2006 NaviDrive RT3
2006-2013 NaviDrive RT4/5
2007-2013 MyWay
2012-2014 eMyWay
2007-2012 Citroën C-Crosser
2007-2012 Mitsubishi/Rockford HDD
2012-xxxx Citroën C-Elysée
2012-2016 - -
2009-xxxx Citroën C-Zero
2009-xxxx - -
2016-xxxx Citroën e-Méhari
2016-xxxx - -
1994-xxxx Citroën Jumper/Relay
1994-20xx - -
20xx-20xx NaviDrive RT3
20xx-2012 NaviDrive RT4/5
2012-xxxx TomTom Live
1995-xxxx Citroën Jumpy/Dispatch
1995-2005 - -
2007-2012 MyWay
2012-2016 eMyWay
2016-xxxx (Jumpy III) Citroën Connect Nav
2007-xxxx Citroën Nemo
2007-xxxx - -
2016-xxxx Citroën SpaceTourer
2016-xxxx Citroën Connect Nav
1989-2000 Citroën XM
1989-1998 - -
1998-1998 (XM Multimedia) Magneti Marelli RPNav200
1998-2000 - -
2010-xxxx DS 3 (voorheen Citroën DS3)
2010-2012 MyWay
2011-2015 eMyWay
2015-xxxx (New DS 3) SMEG+
2011-xxxx DS 4 (voorheen Citroën DS4)
2011-2015 eMyWay
2015-xxxx (New DS 4) SMEG+
2011-xxxx DS 5 (voorheen Citroën DS5)
2011-2015 eMyWay
2015-2016 (New DS 5) SMEG+
2016-xxxx DS Connect Nav
2017-xxxx DS 7 Crossback
2017-xxxx DS Connect Nav
Systeemherkenning
Wil je weten welk navigatiesysteem in jouw Citroën of DS is ingebouwd? Voer dan je VIN (chassisnummer) in op citroen.navigation.com. Heb je je VIN niet bij de hand, gebruik dan de onderstaande beschrijving.
NaviDrive RT3
Numerieke toetsen in het midden, ronde knoppen links en rechts, menusymbolen op scherm in een rij, geheugen: CD-ROM.
NaviDrive RT4/RT5, Citroën C5 en Citroën C6
Numerieke toetsen rechts, ronde knop in het midden, menusymbolen op scherm in een cirkel, harde schijf, update via CD-ROM.
NaviDrive RT4/RT5, overige modellen
Numerieke toetsen in het midden, ronde knoppen links en rechts, menusymbolen op scherm in een cirkel, harde schijf, update via CD-ROM.
NaviDrive 3D NG4
Alleen C5 (2007-2012), ronde OK-knop in het midden, numerieke toetsen rechts, harde schijf.
MyWay RNEG
Grote min- en plustoetsen direct onder scherm, SD-kaart.
eMyWay RT6
Drie toetsen Nav – Traffic – Phone in het midden, ronde knoppen links en rechts, harde schijf, update via USB.
Alleen in C-Crosser en C4 Aircross, harde schijf, update via DVD.
TomTom Live
Alleen in Jumper vanaf 2012.
Garmin nüvi 56LM EU
Af-fabriek alleen in C1 II vanaf 2014, ook als officiële Citroën-retrofit op andere modellen. Semi-geïntegreerd, af-fabriek op houder aan A-stijl, als retrofit ook wel op bovenzijde dashboard.
SMEG+
7” tactiel scherm (optioneel met Mirror Screen), harde schijf, update via USB.
Citroën/DS Connect Nav
7” tactiel scherm met Mirror Link en CarPlay, harde schijf, update via USB.
NaviDrive RT3
Selecteer “boordcomputer”, selecteer “navigatie-opties”, selecteer “CD-omschrijving”.
NaviDrive RT4/RT5
Selecteer “navigatie”, selecteer “navigatie-opties”, selecteer “kaartversies”.
NaviDrive 3D NG4
Druk op “Set Up”-knop, selecteer “systeemgegevens”.
MyWay RNEG
Druk op “Set Up”-knop, selecteer “systeemgegevens”, selecteer “kaartversies”.
eMyWay RT6
Druk op “Nav”-knop, selecteer “kaartmanagement”, selecteer “kaart en updates”.
SMEG+
Houd “Instellingen”-knop enkele seconden ingedrukt, selecteer “kaartversie”.
Indien je updates van kaarten liever via internet koopt dan bij een Citroën- of DS-dealer, kun je terecht op de volgende websites.
NaviDrive RT3/RT4/RT5/3D
Navteq/Here via citroen.navigation.com
MyWay RNEG
eMyWay RT6
TomTom Live (Jumper vanaf 2012)
TomTom via tomtom.com
Mitsubishi/Rockford HDD (C-Crosser en C4 Aircross)
Garmin (C1 II)
Garmin via garmin.com
SMEG+ (compatibel met eMyWay)
MyCitroën (website per land)
2001-2009 NaviDrive RT3
Centraal navigatietopic NaviDrive RT3
2006-2013 NaviDrive RT4/RT5
Centraal navigatietopic NaviDrive RT4/RT5
2007-2013 MyWay RNEG
Centraal navigatietopic MyWay
2011-2017 eMyWay RT6
Centraal navigatietopic eMyWay RT6
2013-xxxx SMEG+
Centraal navigatietopic SMEG+
2016-xxxx Citroën/DS Connect Nav
Centraal navigatietopic Citroën/DS Connect Nav
Correcties en aanvullingen op het bovenstaande kun je ook in het hier genoemde topic van het desbetreffende navigatiesysteem plaatsen.
