New user, new questions :)
cachirro
Totaal aantal Berichten: 10
Geregistreerd: 03-04-2017
Gepost: 03 april 2017 10:49 AM
Dear Citroen family,
I recently got a 2014 so irresistible DS3, and i have a few questions.
1. how can i update the GPS data?
2. how can i recharge the perfume thingy?
3. is there a way to make the windows go down with just one long press of the button? (now i have to keep the button pressed until it goes down all the way)
4. how can i edit (or in last case remove) an entry from the gps database (saved addresses)
Thank you very much for your help.
Gepost: 03 april 2017 11:07 AM
Welcome to Citroën-Forum.nl, cachirro. Perfume cartridges are available at your Citroën or DS dealership, who could also provide you with the latest maps for your navigation system. If you prefer to buy those on the internet, the only legal source would be http://citroen.navigation.com.
cachirro
Gepost: 03 april 2017 11:20 AM
Thanks for your reply Rens, as far as i can see the NL map is for Q1-2017, is there any way to check which version do i currently have?
And do you know anything about my windows question?
Gepost: 03 april 2017 11:26 AM
For the windows I can’t be of any help, but for the navigation system I can Smile. We have put together an overview of all Citroën and DS systems: click! According to that, a 2014 DS3 should be equipped with eMyWay, of which the installed maps could be verified by pushing the “Nav” button, selecting “map management” and then “maps and updates”.
cachirro
Gepost: 03 april 2017 12:43 PM
Thanks Rens,
i will check my gps map version later.
Regarding the perfume thing, i found some recharges but only in UK, does anyone uses an online site to order them? Or does everyone just buys them in Citroen? (no idea about price differences)
Thanks.
Gepost: 03 april 2017 01:08 PM
There’s a whole thread about those perfume cartridges: https://www.citroen-forum.nl/forums/viewthread/209280/. Summary: owners either don’t smell anything or don’t like what they smell…
cachirro
Gepost: 03 april 2017 01:20 PM
ohh, thanks for the tip Rens Smile
ray78
Totaal aantal Berichten: 482
Geregistreerd: 02-05-2011
- DS 3 1.6 eHDI airdream so chic
- DS 3 puretech 110 ines de la fressange 1.2 vti
Gepost: 03 april 2017 09:11 PM
Cachirro,
about the qeustion for your elctric windows: turn your key(in the ignation) on to the first click and then lift your window button up and hold it for a couple of seconds. If this wont do,try to push it down and hold it for a couple of seconds.after this the window will go up and down with just one touch on the button.
Citroen DS3 eHDI So Chic,Gris alu + noir onyx, select comfort, metallisee bicolore, 3D achterlichten
DS3 1.2vti 110pk puretech Innes de la fressange
cachirro
Gepost: 04 april 2017 03:48 PM
i tried it without success Sad
is it in the 1st position? (when the car gets power) or before that?
ray78
Gepost: 04 april 2017 06:06 PM
first position
i’m gonna search for a online manual,see what they say about that.
simply translated they say you’ve got 2 options for the windows:
1st: manual control: pull or push the button until the resistance,the window will stop,if you release the button
2nd: full control: pull or push the button trough the resistance,after releasing the button,the window will go all the way up or down. control the button again to open or close
cachirro
Gepost: 04 april 2017 06:07 PM
Thank you for your help Ray.
cachirro
Gepost: 18 april 2017 01:26 PM
Haven’t been able to make it work yet, must be something really specific that i am failing to reproduce.
cachirro
Gepost: 18 april 2017 02:43 PM
and here is a new question:
cachirro
Gepost: 01 mei 2017 02:35 PM
Can anyone help? Thanks.
Vyper
Totaal aantal Berichten: 70
Geregistreerd: 08-04-2017
Gepost: 01 mei 2017 09:23 PM
I don’t know if you can remove them one by one. You can try to reset the whole system by pressing the eject or power button till it turns off.
cachirro
Gepost: 02 mei 2017 05:27 PM
Thanks for the tip Vyper, the GPS software seems to be very limited then, strange in this modern times to be missing something that simple as an edit or delete function from a saved list.
