Citroen CX 2400 Gti 1979 injector problem
aklemar
Totaal aantal Berichten: 1
Geregistreerd: 12-05-2020
Gepost: 12 mei 2020 11:29 PM
Hi,
Please help.I have a big problem with my cx Gti 2400 made 1979.I dont have a negative puls on fuel injectors.All injectors does not work anymore.On the car is new fuel pump,spark plugs and cables.The car is runing only 3 sec. with choke fuel. Ignition coil and distrubution is OK
Tnx
Alen
Citroensmgz
Totaal aantal Berichten: 3833
Geregistreerd: 21-11-2006
Gepost: 13 mei 2020 12:14 AM
Your injection computer ( Bosch L-Jetronic) is not working correctly. Start to check if it get’s power, it has good earthing and the connectors are OK.
If the cars runs a couple of seconds when you start, this means the “start” procedure works so you ECU should have power. because there is a separate cold start injectors.  You conclude your main injectors are not switched on. Your next point is to see if ECU get’s a signal from the ignition module: The Distributor gives a signal to the ignition module, which then gives pulses to the injection computer to inject. . Look for schematics to know what wires to check.
Rogier 1975
Totaal aantal Berichten: 1205
Geregistreerd: 17-09-2004
- XM V6 Pallas
Gepost: 13 mei 2020 10:04 AM
And: the fuel pump is switched by a double relay.
- One part is switched when applying the starter motor - this part apparently works fine
- Second part is switched when the motor is running, by a signal from the air measurement unit - seems this signal is not arriving, or the relay is faulty?
