SM Ignition Switch
Stratos
Totaal aantal Berichten: 5
Geregistreerd: 24-07-2021
Gepost: 24 juli 2021 09:13 PM
Hi Netherland Citroen fans
I hope it’s allright to write in english, as my dutch is quite rusty. Meanwhile I address an issue here as the concentration of specialist petrol heads to my experience are pretty high here ?  (positive meant).
I am a former Citroën Club member in Denmark (Visa GTi + XM V6) and know some dutch Citroën enthusiasts, (Voetel family).
However I think I must ask the community for this one.
My friend has a Citroën SM for restauration, and through the process he demolished the Ignition Switch beyond repair.
New such things are hard to get, so he found another similar switch from another Citroën, has 8 wires as the SM.
Now I need to clone them. I am an Electronic Engineer.
The “new” one has 4 positions; 1.Off - 2.On (something - probably the radio) - 3.Ignition - 4.Starter engage. 8 wires.
Question; Does the SM Ignition Switch also have 4 positions?
Your help will be much appreciated.
Stratos
Gepost: 24 juli 2021 09:15 PM
Citroensmgz
Totaal aantal Berichten: 4147
Geregistreerd: 21-11-2006
Gepost: 24 juli 2021 11:04 PM
Does this help: It shows the positions from a USA SM.
Position 1: Locked.
Position 2: Free:  Can be used for accessories.
Position 3: Contact.
Position 4: Start
If I remember well the Free position has one wire connected, the “Contact” position 2 switched wires.
Stratos
Gepost: 25 juli 2021 09:51 AM
It sure helps a lot.
Thank you so much for your quick response and the file. Just what I needed.
Stratos
Gepost: 25 juli 2021 09:58 AM
(Fighting to get my complete message through)
Totaal aantal Berichten: 26076
Gepost: 25 juli 2021 01:28 PM
Where did you get the switch from, stratos?
Stratos
Gepost: 26 juli 2021 09:04 PM
I asked him. He aquired the switch more than 10 years ago, so he does not remember.
Meanwhile - I just sat and measured the sets through.
There are four sets of switches, which conduct in a reasonable manner;
1. off - on - on - off   could be radio
2. off - on - on - off   could be lights
3. off - off - on - on   ignition
4. off - off - off - on   starter
I found same functions on the old one.
Citroensmgz
Gepost: 27 juli 2021 08:05 AM
That’s the regular wiring set for a Citroen SM and also for some CX’s: They were all made by Simplex.
As Citroen changed the wiring a couple of times you need to follow the wiring diagram to get the exact functions.
The switch on the locked position was for the permanent powered devices, which you however would unpowered if you start the car: The startmotor and ignition needed all the electric energy, no waste for other functions.
