Als je via die link doorklikt kom je op twee mogelijkheden:
Products for Berlingo 2017 Touchscreen 7” with MirrorScreen
met als info:
ABOUT
IMPORTANT:
To identify the software version of the navigation system, follow this procedure:
• Press and hold (for 5 seconds) the ‘SRC’ key on the left touch screen.
• Select: System version
View the version of the displayed software and use the compatible update according to the following versions:
• For a version 3.x, 4.x or a 5x , please choose any Touchscreen 7” (SMEG + iV1) Europe map
• For a 6x version, please choose Touchscreen 7” with Mirror Screen (SMEG + iV2) Europe map1 USB Stick covering Europe. This Peugeot Map Update covers 39 countries
Need more information? Click on the product name to see more information.
Of dit systeem: Products for Berlingo 2017 eMyWay
met als info:
PRODUCT INFORMATION
HERE map of Europe for your Peugeot WIP Nav+ RT6 navigation system.In addition to precise routes, these clear, rich maps feature many POIs: golf courses, theatres, hotels, car lots and much more making this latest edition of Peugeot digital map the perfect guide to traveling through Europe.
IMPORTANT The minimum software version required to use this product is 2.10. If you have a lower version of software labor time might be charged at the dealership to complete a software upgrade. To check your version, press the ‘setup’ button for a short while, and the help menu will show up. Select ‘device description’ and ‘software’. If your version is lower than 2.10 , we invite you to visit your dealer, who will proceed to the firmware update. Instructions of how to compete the installation are available in PDF format. It is suggested that you read this information prior to purchasing.
En dus de vraag: wat zit er nou in jouw Berlingo?
nou die eerste niet want ik heb geen SCR knop dus het moet de tweede zijn..
maar Menno had ook al ontdekt dat het een Smeg/RT6 systeem is… dus dat is optie 2 toch..
maar goed.. nu dus de vraag hoe je die firmware update dan uitvoert.. want er staat hier dus dat je uitgenodigd wordt om naar de dealer te gaan…
Welke firmware versie zit er nu op, heb je dat al gecheckt?
Is dat minimaal 2.10?
Zie die instructie hoe je dat moet checken.
gevonden
SMEG6.4.A.R10
CD 31210
16-06-17
maar er is nergens iets van een software versie te vinden in de range van 2.10
dit komt er te staan als ik de instellingen knop ingedrukt houdt en naar software ga
Dat zo lezend heb je geen RT6/eMyWay maar een SMEG met Firmware 4.x
Heb je een touchscreen?
ja een touchscreen maar ook een menuknop waarmee je kunt navigeren
maar moet deze firmware ook geupdate worden dan? en hoe?
Het verhaal hierboven lezend hoef je de firmware niet te updaten.
Maar er moet wél de juiste versie van de kaarten gekozen worden:
Als je denkt die gratis te kunnen krijgen bij Citroën, zou ik hen benaderen en vragen hoe dat dan gedaan moet worden.
Dat stuk heb ik al beschreven in dit topic..
De zipfile wordt verstrekt gratis maar citroen weigert de bijbehorende instructies te verstrekken. Als je die nodig hebt moet je gewoon een afspraak bij de dealer maken om het tegen betaling te laten doen.
het gaat dus hierom:
https://psa.download.navigation.com/automotive/PSA/RT6-SMEGx/M49RG20-Q0421-2001.ZIP
Ik vrees dat wij hier, op dit forum, er verder weinig aan kunnen bijdragen.
We hebben voor je uitgezocht welk systeem er in jouw Berlingo zit, hoe je verder kunt checken wat de status is.
Je Berlingo is geen standaard exemplaar, het is een elektrieke, met ook nog eens een Navi erin die niet bouwjaar-conform is. Dat zou een reden kunnen zijn waarom je vastloopt.
Dan zijn er naar ik denk twee mogelijkheden:
—Je gaat naar een dealer en vraagt hem dit te regelen. En tegen welke prijs dat dan zal zijn.
—Of je koopt ‘m voor € 129 via de link die ik eerder gaf.
We zijn benieuwd naar het vervolg.
Had je de USER Guide die daar te vinden is ook al bekeken?
JW schreef:Ik vrees dat wij hier, op dit forum, er verder weinig aan kunnen bijdragen.
Je Berlingo is geen standaard exemplaar, het is een elektrieke, met ook nog eens een Navi erin die niet bouwjaar-conform is. Dat zou een reden kunnen zijn waarom je vastloopt.Dan zijn er naar ik denk twee mogelijkheden:
—Of je koopt ‘m voor € 129 via de link die ik eerder gaf.We zijn benieuwd naar het vervolg.
nou.. het is inderdaad nu duidelijk welk systeem er in zit.
Dat de berlingo geen standaard exemplaar is met een verouderde Navi is volgens mij niet relevant.
Het type auto doet dan ook niet ter zake en was alleen belangrijk om uit te vinden welke Navi gebruikt werd. En dat het een ouder type Navi is zou juist een voordeel moeten zijn want dat betekent dat de afgelopen 7 jaar dit type al gebruikt is en er dus op dit forum juist veel over bekend zou moeten zijn.
Ik heb juist dit bericht gepost omdat ik het een beetje vreemd vind om naar een dealer te gaan aangezien ik 5 jaar gratis updates krijg. Tenminste dat lijkt nu een beetje een wassen neus.. maar dat is wat citroen zegt te doen.
Kopen is helemaal niet nodig want dan krijg ik dezelfde datawaarschijnlijk, mogelijk dat bij die prijs dan wel support zit, maar ik betwijfel het als die van dezelfde lui afkomstig is als de link die ik nu al heb.
Je wil dus zeggen dat er niemand op dit forum is die iets afweet van een navigatiesysteem wat door citroen al meer dan 7 jaar gebruikt wordt?
JW schreef:Had je de USER Guide die daar te vinden is ook al bekeken?
Die heb ik niet bekeken. Nu wel en die is voor een ander systeem. met die SRC knop. Die heb ik niet.
Mabuti schreef:......
Het is de vraag of dit systeem “al meer dan 7 jaar” door Citroën gebruikt wordt.
Het is in 2017 in jouw Berlingo gezet, maar waarin nog meer? Het jaar daarna kwam het NAC systeem.
Ik kan je niet verder helpen, anders dan te suggereren toch naar je dealer te gaan.
Heb je daar deze Berlingo ook aangeschaft? En is ‘ie daar in onderhoud?
Als dat het geval is, doet de dealer dat wel bij een onderhoudsbeurt…...
Dat systeem is toch alleen maar van Citroen en Peugeot.
Lijkt me niet dat dit maar in 1 type auto is gebruikt in 1 jaar in 1 model.
Zo werken dit soort bedrijven niet.
Ik denk dat het de laagste klasse is geweest die behoort bij heel veel standaarduitvoeringen.
Onderhoudsbeurt is de komende jaren nog niet van toepassing. Zoals je weet hoeft dat met een dergelijk voertuig maar eens in de 5 jaar ongeveer.
Daar is niet veel aan te onderhouden.
En zijn er niet meer mensen in dit forum die er iets van af weten dan?
Dit systeem zou toch in meer dan een miljoen voertuigen moeten zitten in Europa alleen al en ik zag dat het in de VS ook veel gebruikt is of nog altijd wordt.
