Gearbox
Greeney
Totaal aantal Berichten: 170
Geregistreerd: 09-06-2007
Gepost: 08 juli 2007 12:16 AM
Has anyone removed a gearbox from the DS?
I undid all the bolts except 2 which did nt have the normal type head Is it a special tool? and why ever would Citroen do that? Or is that a silly question
http://WWW.CLASSICALLYFRENCH.COM
http://tractionavant.forumcircle.com/portal.php
We do these things not to escape life but to prevent life escaping us
Greeney
Gepost: 08 juli 2007 12:18 AM
Sorry forgot to say…
It is done now as you can see but what a performance. 2 broken 6mm spanners too
Greeney
Gepost: 08 juli 2007 11:20 AM
Sorry I keep unloading pics then moving them Surprisedops:
Also the trouble with barn finds is straw and mummified Rats
Laughing
vikingo
Totaal aantal Berichten: 736
Geregistreerd: 10-05-2005
Gepost: 08 juli 2007 01:48 PM
where is this bolt comming from, never seen it before.
alexander
Totaal aantal Berichten: 813
Geregistreerd: 15-01-2006
- ID/DS ID 19 P
Gepost: 08 juli 2007 02:08 PM
I ‘ve took two of those bolts out of my transmission (ID ‘62) Special socket is available @ Chyparse.
Good luck!
Greeney
Gepost: 08 juli 2007 04:37 PM
They go on the bellhousing of the gearbox about middle horizontal.
Why they would do it I dont know just the 2 (one on each side) all the rest were normal bolts.
Rolling Eyes
alexander
- ID/DS ID 19 P
Gepost: 08 juli 2007 11:35 PM
Rolling Eyes
Maybe there’s not enough room for regular bolts, I’m not sure! Have to look into it next week!  Confused
Gepost: 09 juli 2007 01:35 PM
That is the reason. Use those hexagonal ones at rebuilt
alexander
- ID/DS ID 19 P
Gepost: 09 juli 2007 01:37 PM
Good idea! Wink
> 11000 berichten
Totaal aantal Berichten: 11979
Gepost: 09 juli 2007 04:23 PM
Allen-type bolts or Inbus as we call them?? Good idea! But use lots of copper grease, you do NOT want those to stick should you need to take the ‘box back out… Cost me several moped-engines, stunts like that…
Gepost: 09 juli 2007 05:04 PM
I have left them out all together… The “wielewaal” ( the original) is a pretty type of bolt but I did not see the need.
An Allen kan be unscrewed with the proper bit on your wrench.
vikingo
Gepost: 09 juli 2007 05:45 PM
bogaard:
van waar komt die bout, heb ik nog nooit gezien bij demontages.. ik ben heel nieuwsgierig..
Gepost: 09 juli 2007 05:51 PM
Zet de bak vast aan het blok. ik dacht de 1 na onderste aan beide zijkanten.
wbogaerts
Totaal aantal Berichten: 3198
Geregistreerd: 16-06-2005
- SM 2.7 Carburateur
- C5 exclusive
- Berlingo 1.4 I multispace
- 2CV special
Gepost: 10 juli 2007 01:26 AM
Yep , is dezelfde kop als de bout van de hoogteregelaar rond de torsiebar .
Vroeger plaatste ik hier altijd een gewone M7 in .
De oude M7 bouten hadden nog een kop van 12 mm , nieuwere zijn maar 11 mm .
Vandaar deze speciale koppen , die sleutel gebruikten ze toch al dus waarom niet .... Wink
Walter
