2 van de 2
 < Vorige 1 2
New aquisition
Totaal aantal Berichten: 12035
Gepost: 10 juli 2007 01:09 PM
Oops, I somehow overlooked that…  Surprisedops: But it’s in my Favourites now, so it should present no more problems in the future! Thanks!
Greeney
Totaal aantal Berichten: 170
Geregistreerd: 09-06-2007
Gepost: 10 juli 2007 10:51 PM
Pictures added on site Shocked
http://WWW.CLASSICALLYFRENCH.COM
http://tractionavant.forumcircle.com/portal.php
We do these things not to escape life but to prevent life escaping us
Gepost: 11 juli 2007 12:57 AM
Very helpful - Thanks a bunch!
Greeney
Gepost: 12 juli 2007 12:39 AM
This is the upturned floor pan of the DSuper surface rust with only a couple of minor holes…I am very pleased… (apart from the boot floor though)
The cill plate on the left has a 100mm corrosion line level where the inner boxing meets the floor. The outer cill plates are good apart from a little hole on the right section just below the B post.
More Photos on my Site
Cool  Shocked
Dirkman
Totaal aantal Berichten: 963
Geregistreerd: 14-05-2006
Gepost: 12 juli 2007 01:41 AM
so?
.komma
Greeney
Gepost: 12 juli 2007 11:19 AM
SO?... Is that one of your dutch “So” exclamations or is that a “so” question? I am not putting it back together I dont have enough good part elsewhere unless I find another with a bad chassis rest ok.
If it was a “so what” I am sorry to have bored you Surprisedops:
alexander
Totaal aantal Berichten: 813
Geregistreerd: 15-01-2006
- ID/DS ID 19 P
Gepost: 12 juli 2007 11:53 AM
Hi Nick,
How did you turn it over without distorting the upper structure of the frame, I always felt that part of the frame was rather weak!
The frame doesn’t look too bad, I have seen much worse.
Take care
Alexander   Cool
Thijs
Totaal aantal Berichten: 4959
Geregistreerd: 18-09-2004
Gepost: 12 juli 2007 12:00 PM
Looks great Greeney, i’d wish i had that space to dismantle my CX Smile Keep up the good work Exclamation
gerardeux
Totaal aantal Berichten: 318
Geregistreerd: 23-11-2005
Gepost: 12 juli 2007 03:04 PM
Penny Lane schreef:
I’d wondered about how the spaceframe was conceived. But that’s all getting quite a bit clearer! With your chassis being stripped for easy acces, would you mind taking pics of the inside of the sills?? Derk
Derk, besides the useful pics of Greeny, I think you will be interested in the site below where under CitroenDS/technical data/chassis/sills the construction and different parts of the sills are clearly visible.
Gepost: 12 juli 2007 11:27 PM
Yes that does help, Gerardeux, thanks! I do have the parts books with all sorts of exploded views, but sometimes you just need to see the whole structure in stead of just the bits… And there is definitely some welding needed to the center supports inside the sills. No problem though… And my boot floor is 99,5% intact Mr. Green
Greeney
Gepost: 12 juli 2007 11:55 PM
A friend and myself turned it over I am fairly strong (ex rugby player) Shocked but it is not all that heavy, I felt rolling it would be dangerous so we flipped it over in one and gently put it on its roof which I hasten to add is not weak at all, it is basically an evenly balanced ring with 6 supports. I wouldnt put too much weight anywhere, like climbing on it, for instance though. I am doing the welding needed today and tomorrow and putting it back on its bottom on saturday after rust treating all the bare metal
Greeney
Gepost: 14 juli 2007 01:09 AM
Windows
Today I have experienced removing everything from the doors including the glass, The handles and trim were pretty straight forward but the Glass was a different story. The first one took me half an hour, the second 20mins, the 3rd and 4th about 10mins Cool I used a flat piece of steel to unhook the glass from the sprung bar of the mechanism but I am sure there must have been a tool for it. If you ever have to remove/replace a door lock mechanism you will have to remove all the glass and runners first Rolling Eyes
bartjes
Totaal aantal Berichten: 1452
Geregistreerd: 02-02-2007
- ID/DS DSuper LPG 5bak
- Xantia 1.8 16v Break
Gepost: 14 juli 2007 06:59 PM
Re: Windows
Alternate solution: go to the gendarmerie, ask if they have locked away a car-jacker, and ask him how he enters cars without smashing the (side) windows .....
Greeney
Gepost: 14 juli 2007 08:48 PM
Dutch sense of humour tres drole:roll:
2 van de 2
 < Vorige 1 2
