Totaal aantal Berichten: 5830
Geregistreerd: 27-07-2003
- ID/DS D-Super
In 1953, a fledgling company called Rocket Chemical Company and its staff of three set out to create a line of rust-prevention solvents and degreasers for use in the aerospace industry, in a small lab in San Diego, California.
It took them 40 attempts to get the water displacing formula worked out. But they must have been really good, because the original secret formula for WD-40—which stands for Water Displacement perfected on the 40th try—is still in use today.
Convair, an aerospace contractor, first used WD-40 to protect the outer skin of the Atlas Missile from rust and corrosion. The product actually worked so well that several employees snuck some WD-40 cans out of the plant to use at home.
A few years following WD-40’s first industrial use, Rocket Chemical Company founder Norm Larsen experimented with putting WD-40 into aerosol cans, reasoning that consumers might find a use for the product at home as some of the employees had. The product made its first appearance on store shelves in San Diego in 1958.
In 1960 the company nearly doubled in size, growing to seven people, who sold an average of 45 cases per day from the trunk of their cars to hardware and sporting goods stores in the San Diego area.
In 1961 the first full truckload order for WD-40 was filled when employees came in on a Saturday to produce additional concentrate to meet the disaster needs of the victims of hurricane Carla along the U.S. Gulf coast. WD-40 was used to recondition flood and rain damaged vehicles and equipment.
In 1969 the company was renamed after its only product, WD-40.
WD 40 is ook een verrekte goed middel ! Leuk het verhaal er achter eens te lezen.
En wist u dat ik zin heb in a.s. zondag en de zaterdag er op ?
Schijt aan originaliteit.
...Ik me afgelopen zaterdag heb ingeschreven bij het Scheepvaart en transport College Jan Backx in Rotjeknor?
...Ik het geeneens een leuke school vind…
... ik waarschijnlijk dan dingen moet inhalen terwijl het dezelfde opleiding met dezelfde lesstof is als wat ik nu doe…
... er alles aan doe om maar lekker in Den Bosch te kunnen blijven…
...ik anders na deze 10 weken weer 20 op stage kan gaan…
...ik toch echt liever naar school ga
... ik nog steeds mijn achterwiel van mijn brommer niet weggebracht heb…
... ik ontzettend veel zin heb in zaterdag…
... ik in zo’n zelfde soort topic op het forum van Zoetermeerders.nl ook al heel veel heb lopen blaten…
...ik nu even niets meer weet te zeggen…
...ik maar een nieuw forum spelletje ga introduceren…
Ex BX 16v, Ex AX GTI
- ID/DS D-Super
....er en speciaal klaagtopic is binnen dit forum
Blueduck schreef:ff terug op dat wd 40.. mn bumpershine kon ik niet vinden, dus vandaag mn bumpers opgepoetst met wd40 Glimt als de neten!!!
Ik gebruik het ook altijd voor de(nu nog weinig over gebleven) nylon onderdelen. eerst afwassen met water en dan insprayen met WD-40 en het teveel aan wd-41 er weer af vegen….En iedere keer ziet ie er weer als nieuw uit
- ID/DS D-Super
dus jij spuit er wd 40 op en dan kun je er wd 41 afvegen?
Totaal aantal Berichten: 27934
kan je dat op de (zwarte) kunstof delen van je bumper doen?
en voor welke delen is dat nog meer geschikt?
erik wijngaarden schreef:dus jij spuit er wd 40 op en dan kun je er wd 41 afvegen?
Jah, om de ene of andere vreemde manier heb ik altijd een ander mengseltje over als wat er uit het busje komt
oke dat wist ik idd nog niet dat je daarmee goed kon schoonmaken
misschien ook is even keer zo’n bus WD40 halen
moet je nog oppassen voor je lak of iets anders?
na het inspuiten van de delen afnemen ofzo en dan klaar?
Totaal aantal Berichten: 3779
Geregistreerd: 25-05-2004
- XM 3.0 V6 24v
- XM 2.0i 8v
Wist U dat…
- de broodjes van Delifrance echt uit frankrijk komen?
- de broodjes uit fabrieken uit Nivelles, Bethune en Vendin-le-Vieil komen?
Vooral door blijven gaan met WD-40. Vooral aankomende zomer, je hele auto mee insmeren. Kun je je gelijk inschrijven bij de onopvallende brigade van de landmacht. Kun je dienst doen met je cameleonvoertuig, aangezien olie stof aantrekt en vasthoud
