Hydraulic Pump
Greeney
Totaal aantal Berichten: 170
Geregistreerd: 09-06-2007
Gepost: 03 mei 2008 11:46 PM
I have ordered my new pump and accumulator sphere it will arrive next week Cool
Can any one offer any tips or advise before I dismantle everything?
Do I have to de pressurize even though it is leaking badly?
Any tips on how to go about bleeding the system
Where exactly is the accumulator?
This one is new to me having never done it before so help much appreciated
Thank you
My car is the 1971 Pallas 21Injection 3pulley and BVH gearbox Cool
I have already removed the wings as I have been revising the lights
Thank you
http://WWW.CLASSICALLYFRENCH.COM
http://tractionavant.forumcircle.com/portal.php
We do these things not to escape life but to prevent life escaping us
Totaal aantal Berichten: 25571
Gepost: 07 mei 2008 12:23 PM
Yes, Depressurize! Or do you like LHM in your eyes and hair?
Remove the connection of the leads before removing the pump! Install the pump, install the lead, NOT TIGHT. give the belt tension, THEN tighten the lead. FILL THE PUMP before you start!!
To find the accumulator: Follow the big lead from the pump! Probably located lefthand side of the engine. To remove the sphere, work from the bottom up! Or remove the alternator and remove the entire High pressure unit!
good luck.
fluidphreak
Totaal aantal Berichten: 2259
Geregistreerd: 28-04-2006
Gepost: 07 mei 2008 02:08 PM
To fill the pump, fill the filter and hose to the pump with LHM fluid, then quickly place it into the fluid container without spilling too much.  Smile
Next, start the engine and let it idle while you still have a loose ‘depressurize bolt’ on the pressure regulator (the size 12 one). This allows the pump to suck the LHM fluid easily because no pressure has to be produced yet. After a minute or so, tighten the size 12 bolt on the pressure regulator after which the car should rise.
Greeney
Gepost: 07 mei 2008 09:16 PM
Ah thank you very much I didn’t think I was going to get an answer Rolling Eyes
That is great detail I should be able to manage that well enough
gjvdh
Totaal aantal Berichten: 809
Geregistreerd: 12-05-2006
- ID/DS DS 20 Pallas BVH
Gepost: 07 mei 2008 09:42 PM
Be sure to use a new rubber seal sleeve on the hydraulic pipe to prevent leakage.
Greeney
Gepost: 07 mei 2008 09:49 PM
Yes I have a good selection now as I bought a complete pipe kit including flare maker 50metres of various size pipe and all the seals etc
