Fuel pump
Citrobert
Totaal aantal Berichten: 60
Geregistreerd: 12-09-2007
Gepost: 12 mei 2008 01:30 PM
Greetings!
I need a new fuel pump for my 1970 SM Carburettor. Can anyone tell me how much pressure the pump is supposed to deliver? (electric feeder placed just in front of right rear wheel…)
Cheers,
Robert
Blooper1963
Totaal aantal Berichten: 4695
Geregistreerd: 26-08-2005
- SM 2.7 carb
- C3 1.4 HDI exclusive
Gepost: 12 mei 2008 01:41 PM
The RTA tels, MAX 330 milibars!
Citrobert
Gepost: 12 mei 2008 02:33 PM
Thanks!
Does it have to be original part?
Totaal aantal Berichten: 43324
Gepost: 12 mei 2008 02:39 PM
Citrobert schreef:
Thanks!
No, it does not have to be an original part. However: You can find a replacement pump on Ebay-motors.com. The fuelpump used on the Sm is made bij Facet, and if you just search ebay on that name, you could by a lucky man!
Citrobert
Gepost: 12 mei 2008 05:57 PM
Thanks, Waterman!
wbogaerts
Totaal aantal Berichten: 3197
Geregistreerd: 16-06-2005
- SM 2.7 Carburateur
- C5 exclusive
- Berlingo 1.4 I multispace
- 2CV special
Gepost: 13 mei 2008 12:16 AM
Be sure its the right pressure Exclamation  Exclamation
Walter
Citrobert
Gepost: 13 mei 2008 11:49 AM
Walter
I got a tip from members of the Norwegian club that this pump will do the job:
Max. cap: 70 l/h.
Max. pressure: 0,27–0,40 bar.
Do you think it’s OK?
Cheers,
Robert
Gepost: 13 mei 2008 12:46 PM
Citrobert schreef:
Walter
Max. cap: 70 l/h.
Cheers,
Robert
YES! I think that’s the one you will need. It looks just like the one on my own car, and the pressure is right to.
Citrobert
Gepost: 13 mei 2008 07:16 PM
Great!
It works brilliantly!  Smile
wbogaerts
- C5 exclusive
- 2CV special
Gepost: 13 mei 2008 09:24 PM
yes this is the right one .
Where do you get it ??
Where are you living ??
Greatings ,  Walter
PBuijsman
Totaal aantal Berichten: 314
Geregistreerd: 16-06-2006
- SM 2,7 IE
Gepost: 13 mei 2008 10:24 PM
Iemand ervaring met een Pierburg pomp voor de injectie?
Gutta cavat lapidem…
Gepost: 13 mei 2008 10:32 PM
Pierburg sucks. Buy a Bosch. It’s no wonder Pierburg is bankrupt…
wbogaerts
- C5 exclusive
- 2CV special
Gepost: 13 mei 2008 11:54 PM
Heb waarschijnlijk nog een Belg die mogelijk een Boch pomp over heeft :
Hij had een nieuwe gekocht opdat hij dacht dat zijn pomp defect was, de benzine spoot er langs alle kanten uit en hij had meer dan 10 bar druk .
Bleek op het einde een verstopte retourleiding in de benzinetank te zijn Rolling Eyes
Walter
Citrobert
Gepost: 14 mei 2008 02:07 AM
Greatings ,  Walter
I live in Oslo, Norway.
We have this BILTEMA brand with stores in all the cities of a certain size here. That’s where they have this pump.
Cheers,
Robert
