2 van de 2
 < Vorige 1 2
Headlamps
Greeney
Totaal aantal Berichten: 170
Geregistreerd: 09-06-2007
Gepost: 08 september 2007 12:43 AM
That was very good of you to photo that for me. I see what you mean the yellow just looks like a sleeve.
I am going to investigate this weekend by taking the easy wing off and having a look to see what I can do and take some measurements If I do manage to find a H4 modification I will obviously have to decide on yellow or white light Rolling Eyes  decisions decisions Rolling Eyes
http://WWW.CLASSICALLYFRENCH.COM
http://tractionavant.forumcircle.com/portal.php
We do these things not to escape life but to prevent life escaping us
> 11000 berichten
Totaal aantal Berichten: 11932
Gepost: 08 september 2007 04:21 PM
The yellow on most lamps available now is indeed a sleeve. That makes life sooo much easier, as you can re-use the sleeve up to a certain extent, which means that you need to buy only one set of yellows - after that, white ones’ll do the job!!
Greeney
Gepost: 08 september 2007 08:34 PM
I had one on my 2cv Fourgonette so I took it apart (easily) and found also it is plexiglas not glass so as you say could outlast a few bulbs Cool
Taking the wing off tomorrow so maybe a photo to follow.
Totaal aantal Berichten: 25830
Gepost: 10 september 2007 01:42 PM
There are however white lamps that are not long enough! The yellow glass sleeve fits but on some DS types the connector gets flipping off the connector pins! I do not know specific brands but compare when buying!
The connector is the big one that has to be screwed on to hold the lamp.
2 van de 2
 < Vorige 1 2
