Assistance on Numbers
Greeney
Totaal aantal Berichten: 170
Geregistreerd: 09-06-2007
Gepost: 25 september 2008 01:17 AM
Can someone help me out with numbers on metal tags;
My ID plate is OK, is self explanatory and is correct for its year and model but below this there is what I presume as an engine plate with EN08013 but the plate on the engine is more detailed it says
AX10103 and then below that it says 4MPV B78
Does this mean its had a different engine at some time
There is also a small strip number under the dash and one on the front suspension unit both different
It is an 11B February 1954
Thank you
http://WWW.CLASSICALLYFRENCH.COM
http://tractionavant.forumcircle.com/portal.php
We do these things not to escape life but to prevent life escaping us
