Water pump
Greeney
Totaal aantal Berichten: 170
Geregistreerd: 09-06-2007
Gepost: 12 oktober 2008 12:58 AM
I have purchased a complete rebuild kit including the main shaft and Bronze bearing for the water pump.
How do I fit the new bronze bearing into the relevant place, I havent done anything to it apart from dismantle the old shaft and bearing and the original bronze sleeve looks well and truly in place. Do I need to heat the casting to remove or replace or will it tap out and in?
http://WWW.CLASSICALLYFRENCH.COM
http://tractionavant.forumcircle.com/portal.php
We do these things not to escape life but to prevent life escaping us
