Jumpy III defective pneumatic suspension
Gepost: 11 maart 2010 06:16 PM
Hej,
I don’t speak too much Dutch, so please in English if possible - Thanks!
Is here anybody who has problems with the rear pneumatic suspension of Jumpy III (built 2009 or later)? The problem with mine is that there is only a very short travel from normal position downwards, approx. 5mm, the lowest position cannot be reached, and every little height difference in the street surface can be felt in tha back awfully.
There seems to be a change in production since early 2009. the yellow parts, called limiter for the suspension travel, are very stiff plastic instead of smooth rubber in the elder model years.
I’d be happy to hear from anyone having the same problems…
thanks and best regards
