My Raid Arctique CX has a 2400ie petrol engine with a distributor and ecu. I need:
1) a replacement coil inside the distributor
2) the ‘amplifier’ module under the coil
Does anyone have these spares please? If so would you post them to me in Australia? Let me know what you want!
Thanks
Does anyone know if the 123 conversion done by Hebels will work with the 2400 injection setup?
1924 5CV la petite citron, 1970 DS Pallas BVH, 1973 D Super 5
1981 CX Pallas C-matic, 1981 CX Super Familiale C-matic “2014 Raid Arctique”
2011 C5 Comfort Hdi 6 speed auto
Totaal aantal Berichten: 17407
Hi Ross,
It seems that the forum community has failed to notice your request for help. Sorry for that! You could try at Garage Hydraulique, the sponsor of the Raid Arctique that made the spare parts available to us on loan. They have a huge stock of parts, new as well as used ones.
Good luck!
Rens
Dank Jim.
For the lead on fog light brackets. I’ve followed that up. Re other parts: the most helpful have been Garage Hydraulique and Leontien. He has the parts and has offered advice via email on what to check. Thanks Leontien.
We have worked our way through the various relays, sensors and wiring. The next area we will check is fuel flow and pressure. Have to lift “Pascale” off her belly first to get to the fuel pump.
Ross
